GM Techs Please Help....
Old Jul 1, 2007 | 03:27 PM
FastCrewCab4x4's Avatar
Default GM Techs Please Help....
Yesterday I replaced the Battery on My 04 Silverado 2500. After that while driving the A/C works only on the Drivers side, The passanger side (DCC) only blows Hot Air. I Have tried switching between Defrost, Heat, Off, everything I can think of. Whats Happening, Or Not Happening. I checked fuses and didn't see any blown ones. anybody have an Idea????? Thanks Allot..
Old Jul 1, 2007 | 04:12 PM
gmforlife's Avatar
I know this might not help, but when i had a mail order tune back in the day, when i disconnected my battery and replaced my pcm, some of my fan controls wouldn't work. Basically the vent air would only blow out of the defrost vents, and not out the dash vents. Basically it returned only by driving, and cycling turning it off, then starting the truck again, running it, turning it off, etc. Hope this helps.
Old Jul 1, 2007 | 06:33 PM
dewmanshu's Avatar
Moderately Differentiated
I learned this weekend the same thing gmforlife mentions...go through some drive cycles first (a week of driving) before you take it to a professional.
Old Jul 1, 2007 | 07:17 PM
wkdivr's Avatar
The HVAC control module has what they call "keep alive memory". If you disconect power, it will have to be driven for awhile to re-learn the settings.
Old Jul 1, 2007 | 07:20 PM
dewmanshu's Avatar
look at that...the person i learned that from!!!
Old Jul 1, 2007 | 07:48 PM
wkdivr's Avatar
Did yours finally start working better?
Old Jul 1, 2007 | 08:52 PM
Dewman, What's the "Clean for Now"?? Did it rain on your way home??? (J/K)
I hope a few driving cycles will correct my problem, thanks allot for all of you guys input...
Old Jul 3, 2007 | 04:24 PM
Well You Guys were right. Today on my way home from work it was working fine. Thanks Again.
Old Jul 3, 2007 | 07:18 PM
gmforlife's Avatar
Good to hear bro, it's funny how that has to relearn itself.
Old Jul 4, 2007 | 12:56 PM
larry1962us's Avatar
The same thing happened to me when I installed my stall. The ac would only blow hot air. A couple of restarts and it started working.
