gas gauge Jumping
gas gauge Jumping
Sometimes whenever I am driving in the message center it says low fuel and the needle is on E . After driving a while the needle goes back to normal . Thoughts ?
I did a search and apparently this is common . To fix it do I really have to drop the tank ? I had hope that it was a loose connection and I would start there except I don't know where the loose connection could be .
Edit :
2001 Silverado 165,XXX
4.8 V8
Edit :
4.8 V8
The problem is corrosion on the metal contacts of the fuel level sender in the tank. Pulling the fuel pump assembly is simple. Remove the 4 bed bolts on the driver side and loosen the bolts on the passenger side. Tilt the bed up and support the underside with a jackstand against the frame. That gives enough room to get the fuel pump module out. All in all, can be done in about 1 hour.
As most have said it is more than likely the sending unit. I will try and take a pic of the contacts this afternoon so you can see what they look like if you are interested.
It could be the stepper motor in the dash as Terravast4 mentioned. If you have a scan tool it could be identified with that. I actually use Torque Pro for my Android phone and love it. If you monitor your fuel level with the scan tool of choice and the level stays steady and it jumps around on the dash it is a good chance that the stepper motor is the problem. If you monitor with the scan tool and it jumps around on the tool it is good chances that the sender is acting up. I use the ELM327 bluetooth connector for Torque Pro. There are also good write ups on this site about Torque Pro.
