Fuel Trims maxed still
Old Nov 23, 2007 | 12:44 PM
  #21
Should I unplug the MAf and start the truck for 30sec or just unplug with out running it? Because I have had that MAF unhooked for a while when i re-sealed the MAF to the Volant box
Old Nov 23, 2007 | 02:05 PM
  #22
thunder550's Avatar
High on diesel fumes
What time are you off work today?
Old Nov 23, 2007 | 02:44 PM
  #23
out of here in 15min
Old Nov 23, 2007 | 08:24 PM
  #24
OrlandoFL4.8's Avatar
I am having the same issues, I have put new header gaskets and sealed the exhaust and cant find intake leaks. Truck is fine when I first start it up, but once it warms up it is maxed out at 25 during idle, everthing else is OK.
Old Nov 24, 2007 | 05:17 PM
  #25
do a vacuum tast just in case, mine came back fine and after some more logging, Thanks to Thunder, we think my MAF is the culprit.
Old Nov 28, 2007 | 06:02 PM
  #26
Thunder, dropped the truck off at the dealer, they are replacing the instrument cluster because of that temp gauge issue after the last time we logged but anyway, they said they hooked up the scanner and ran the truck and my fuel trims were fine and its normal for them to jump around and the highest they saw was 15. I went over to the dealer with print outs of the maxed fuel trims and told them this isnt how it should look, one of the techs said it looked fine to him. Well I pushed forward to the manager and he is going to run and scan the truck himself after the cluster is in tomorrow. I told him **** better be right cause it will be getting logged again.
So after all that you got any opening later this week or next to log?
Old Nov 28, 2007 | 06:27 PM
  #27
thunder550's Avatar
Well that's shitty....it's not gonna throw any codes though, so I dunno what good scanning it is going to do. What they really need to do is replace the MAF sensor, but it doesn't sound like they would be willing to do that. In any case, if they don't come through you should be able to get one for something like $35 or $40 from someone on the forum here.
Next week I should have some time. The rest of this week and this weekend are pretty busy for me.
Old Nov 28, 2007 | 07:20 PM
  #28
yeah the dealer kept telling me if the truck ran that lean it would throw codes all day long. Were there any stored codes from before?
Old Nov 28, 2007 | 07:31 PM
  #29
thunder550's Avatar
When I pulled the codes the only one that I saw was from the MAF being unplugged. There was also something in there about one of the BCMs or something, but it wasn't engine related.
Old Nov 28, 2007 | 07:49 PM
  #30
yeah thats what i thought, he said these engines are real touchy and if it was really that lean my engine light would come on. What a dousch
