Fuel Trims maxed still
justin, I didnt like how the maf was sealed to the box so I used some black silicone and sealed it from the inside and around the MAF as well on the outside of the box. Making sure nothing is near the screen and just by doing this my mid range and upper RPM's have been pulling a lot stronger. Could that of been the culprit?
Are all of your temperature sensors working right? ECT and IAT? Your MAP sensor is working too???
I don't think this would cause maxed fuel trims, but it's something to rule out regardless.
well I am a lucky contestant to work on Friday as well but only till 2pm. We havent decided yet but we may be heading down to buttercup to go hit the dunes but most likely not. I guess I can give you a ring after work and go from there..... Sound good?
Sounds good, call me
Intake tube is on nice and tight and fully on the TB. The tube does not hit the fan shroud either. I think it may of been the way the MAF hooks up to the Volant box so I sealed myself using my own technique which seems to be better as I have been driving it but cant be for sure.
