Fuel Sender Issue?
Old Oct 29, 2012 | 10:58 PM
Slammed96's Avatar
Default Fuel Sender Issue?
A few months ago started noticing that my fuel gauge would work fine until the half tank mark, then stick. Figured it was just a bad stepper motor so had the cluster rebuilt. While my cluster was out I put a known good one in the truck for temporary use. Same problem. Is it a common issue to have the sending unit stick at one point? I put 18 gallons in the truck today with the gauge reading just a hair under half, so I can be sure its a good way off.
Old Oct 29, 2012 | 11:03 PM
2000chevysilverado's Avatar
Mine does it as well pretty common for chevys, mine will read little less then half add another 50 miles then it will drop to empty
Old Oct 29, 2012 | 11:11 PM
Slammed96's Avatar
Great...any good way to fix it? Or just keep a close eye on milage? I go back and forth between McPherson and Manhattan and Wichita a lot, so I dont want to run the risk of running out half way.
Old Oct 29, 2012 | 11:15 PM
Replace whole fuel pump is what I know how to fix it
Old Oct 29, 2012 | 11:18 PM
Slammed96's Avatar
I was afraid that was going to be the answer.
Old Oct 29, 2012 | 11:21 PM
If I remember right its the resistor that needs replaced for the sending unit, I would just buy another and be done with it,
Old Nov 11, 2012 | 05:46 PM
xdmikey's Avatar
Buy another resistor or complete sending unit?
On another Site I read a post where the OP said he replaced the fuel pump and still has a flopping needle.
Is the sending unit part of the pump or separate?
Old Nov 11, 2012 | 06:00 PM
Its part of the pump
wrb002
Aug 31, 2015 12:30 PM
DrX
Aug 28, 2015 08:50 AM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
