frustrating stop light switch issues
Old Mar 30, 2014 | 03:14 PM
nightmare99-__-'s Avatar
Registered User
Default frustrating stop light switch issues
Replaced stop light switch in my truck, its a 99, SOMEHOW advance gave me the wrong year switch (crazy I know) turns out it was for an 03. Put that switch in and it cured my convertor not disengaging lockup with a tap of the pedal. But then my damn breaklights were stuck on. I figured it was a faulty switch so I took it back and got the right year switch because they actually are different. figuring that was the problem I got the right year switch in it and now lockup will not disengage with a tap of the pedal. Ugh. Any ideas?
Old Mar 31, 2014 | 01:04 AM
Suburbazine's Avatar
Your brake switch is the 4 wire type, correct? Brown->Purple is the power interrupt for the TCC, Orange->White is the power to the brake lights. With the switch depressed, key on, there should be no voltage to ground from the Purple wire. If there is, the switch is either wrong, defective or improperly connected.
Old Apr 3, 2014 | 08:57 PM
Registered User
Sorry about the long reaponse time, been a long work week. But yeah its the 4 wire switch. Torque convertor lockup worked correctly with the wrong switch but the brake lights stayed on. I've tried 3 dofferent switches of the correct year and my brake lights work fine but no torque convertor disengaging with a tap of the pedal. Is there a way to properly adjust anything down there? I mean all I could think of is maybe the actual rod that runs off the pedal but I dont see that helping when there is no adjustment where it actually pushes into the switch. The torque convertor shuddering down hills took out the thrust bearings in my last engine so I've been clicking it into tow/haul to disengage the convertor for now. Just pretty annoying-__-
ARC
57
Feb 21, 2022 10:54 AM
bsgiffor
Jul 19, 2015 11:14 AM
rojeho
Jul 12, 2015 06:10 PM
