FOG LIGHTS: adding them to a gmt900 nnbs that originally came w/o fog lights
Old Jan 31, 2011 | 11:20 PM
chris092183's Avatar
Default FOG LIGHTS: adding them to a gmt900 nnbs that originally came w/o fog lights
Anybody know what I need to do in order to do this? Do I need to wire from the pcm to the light or is there already wiring?
I already have the new bumper caps.
Old Jan 31, 2011 | 11:49 PM
fortplainman's Avatar
not sure exactly, but you can get all the parts from your local GM dealership. they would have the part numbers for ya.
Old Feb 1, 2011 | 12:17 AM
Thanks man. I know that is an option but it is probably gonna be the most expensive option. I'm looking for a cheaper way to get it handled. I know I can get connectors online for real cheap. I have plenty of wiring. I just need to know how to wire it up correctly. and what to wire it to or if i need relays. That's more of what I'm looking for.
Old Feb 1, 2011 | 12:27 AM
also are there aftermarket fog lights that are sold with the HID kits? I haven't had any luck.
Old Feb 1, 2011 | 12:52 AM
javzh's Avatar
Just order the fog light kit. I did mine after somebody hit my bumper pad. I didn't have fog lights on mine. It comes with the painted endcaps, fog lights, new switch, and the wiring harness. It was $300 for the kit.
As far as the wiring goes, it just connects into the fuse box, lights, and the switch.
I'll look for the thread..
Edit: here is where it connects into the fuse block
http://www.gm-trucks.com/forums/inde...80&hl=fog+lamp
And they do make hid for our fog lights.
Old Feb 1, 2011 | 01:03 AM
Mangled03gmc's Avatar
Baltimore Whore
They sell a oem kit. All the wires for that kit is in your truck.. Buy the kit, read the deeerections. I added the kit to my truck, it was a breeze
Old Feb 16, 2011 | 12:46 PM
SqwkVFR's Avatar
Dont bother with the OEM fogs unless you just want the look of them. They are useless as lights. Get the PIAA bracket and lights.
Old Feb 16, 2011 | 01:00 PM
Dewey's Avatar
I had the PIAAs on my OBS and they matched the chrome of the bumper and bull bar perfectly, but I don't think that they'd look right on an NBS. However, that's JMO. I actually need to get a new set of fogs because one of mine is busted. FWIW I'm just going to order another set of stockers.
Old Feb 16, 2011 | 01:16 PM
11 Second Truck Club
All u need is the wiring that goes from the fogs to the pcm and the switch inside its already pre wired from gm all u need is the *** switch and it plughs right in
Old Feb 19, 2011 | 11:50 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Its Best to use the factory plug and play kit. FWIW You may need to return to the dealer and have them reflash The BCM to activate the fog light option. Some times the BCM already has this option activated depending on how the truck was built. You wont know till you plug the kit in. it will either work or not.
The kit comes color matched and there is about 7 different part numbers.
19170441 Fog Lamps Clear Lens 24 Watt Lamp, Black (w/ RPO Code 41U, w/o RPO Code T96
19170442 Fog Lamps Clear Lens 24 Watt Lamp, Blue Granite (w/ RPO Code 46U, w/o RPO Code T96
19170439 Fog Lamps Clear Lens 24 Watt Lamp, Graystone (w/ RPO Code 16U, w/o RPO Code T96
19170444 Fog Lamps Clear Lens 24 Watt Lamp, Silver Birch (w/ RPO Code 59U, w/o RPO Code T96
19170443 Fog Lamps Clear Lens 24 Watt Lamp, Summit White (w/ RPO Code 50U, w/o RPO Code T96
19170445 Fog Lamps Clear Lens 24 Watt Lamp, Victory Red (w/ RPO Code 74U, w/o RPO Code T96
19170440 Fog Lamps Clear Lens, 24 Watt Lamp, Dark Blue (w/ RPO Code 25U, w/o RPO Code T96)
