Flashing SES light random missfire
Old Jun 22, 2011 | 12:53 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
If you've already checked everything else, and haven't found anything, pull your fuel rails and dump them into a clean glass jar. You might be surprised at what you find. Water won't pass thru the injectors, I've seen 'em full of water, dirt/sand, rust, etc.
Old Jun 22, 2011 | 01:07 PM
1badblazer's Avatar
I also was reading that some people doing a "Case Relearn" after a motor swap and fixing some misfire issues. Should I do this?
Old Jun 22, 2011 | 01:12 PM
1badblazer's Avatar
Originally Posted by dewmanshu
WTF is a spectrumis? I was hitting the rum when I posted this. Sorry about any nonsense that spewed.
When I say o2 damage I mean all of it. A wire anywhere in the circuit of the o2's. Yes, it's very possible to get misfires without feeling them, but if you have a cam your settings for misfire may be set too high (too sensitive) as well. Can you post your tune?
Ok, when I put the harness in I didn't see any bad spots but I ill check again. No cam yet this is just a stock lq4. There isn't much changed in the tune other than injector data because I am using 06 injectors and also some torque managment taken out.
File Type: hpt
RustyD
May 23, 2016 07:04 PM
legerwn
56
Nov 15, 2015 10:21 PM
Velocity1
Oct 2, 2015 08:01 AM
carid
Oct 1, 2015 09:22 AM
Cammed4ever
Sep 30, 2015 03:38 PM
