filling up AC with refrigerant
You can only hook it up one way (the low side). If your using a DIY kit make sure the clutch is engaging or it will not take unless you jump the low pressure switch with a paper clip or somthing. You have a leak if its low I suggest adding dye if you dont have a sniffer to diag and fix the problem.
