FI tuning start
I have Hptuners and just finished my procharger install. Id like to start my timing at 10* do I change the whole table and start there or certain g/cyl vs rpm like .56+
Jaime
Yeah the PE enable TPS. Conservative then tweak it up a bit as you get comfortable. Lower the MAP KPA to something conservative. Idea being of course to get into PE when you see boost.
PE enrichment obviously.
It might start throwing codes for P0101. I'd probably wait and see or up the table say 10%. Engine Diag> Airflow > Max delta airflow. Keep the laptop with you and at least you can reset it if it does. It will go reduced power mode. There may be a couple other Airflow DTC's that may get upset and tables need to be adjusted. Not coming to me right now.
Cant seem to find the max delta airflow. Just found it funny thing is that its already set at 255? I never touched it so must have been my first tuner.
Well had a chance to change a few things you mentioned. Wow still need to work a few bugs but afr 10.9-11.3 and boost looked around 7psi. You never mentioned how difficult it is to watch afr-fuel psi-boost and lap top while hanging on for dear life. she feels strong timing is still at 10* no knock. Going to bed hospital 5am baby on the way. Thanks
jaime
jaime
Mossyoakglock
Jul 17, 2015 08:30 AM
