Factory electric fans, 03 2500, and HPTuners
How do I change this text
Not dumb I had forgot all about it at first and was using pin 42 and 33 in the same side. now I have pin 42 in one connector and 33 in the other. I just tried using your settings with your hptuner version but still no go. You can turn the fans on manually with VCM controls right? I know I could with the 05's....
i dont know then. yes i can manually turn them on and off with the vcm controls. if you manually ground the pins do they come on? what harness are you using?
42 in the connector toward the engine and 33 in the one towards the fuse box right?
well that sucks. maybe charlie or someone else will chime in. i didn't do anything special for my buddies truck. although his was an 04 like mine. maybe because its a os for a 2500.
