Factory electric fans, 03 2500, and HPTuners
Old Jan 31, 2010 | 01:44 PM
Wilde Racing's Avatar
How do I change this text
Send me yours and your email....
Old Jan 31, 2010 | 01:48 PM
Truckshop's Avatar
coming your way. email is truckshop75@yahoo.com
Old Jan 31, 2010 | 02:10 PM
Truckshop's Avatar
dumb question but are you using the correct pins? 42 in one connector and 33 in the other?
Old Jan 31, 2010 | 02:15 PM
Not dumb I had forgot all about it at first and was using pin 42 and 33 in the same side. now I have pin 42 in one connector and 33 in the other. I just tried using your settings with your hptuner version but still no go. You can turn the fans on manually with VCM controls right? I know I could with the 05's....
Old Jan 31, 2010 | 02:28 PM
Truckshop's Avatar
i dont know then. yes i can manually turn them on and off with the vcm controls. if you manually ground the pins do they come on? what harness are you using?
42 in the connector toward the engine and 33 in the one towards the fuse box right?
Old Jan 31, 2010 | 02:38 PM
yep on the connectors, yep, if I ground the pin manually it works. it has to be in the PCM itself. The harness is a factory harness out of an 05.
Old Jan 31, 2010 | 02:59 PM
Truckshop's Avatar
you don't have the low and high speed wires swapped do you?
Old Jan 31, 2010 | 04:37 PM
Truckshop's Avatar
swap the relays to make sure they are good also
Old Jan 31, 2010 | 04:40 PM
nope, and nope. the fans function as they should if I manuelly ground pin 33. It has to be a program/OS/HPTuners problem...
Old Jan 31, 2010 | 04:52 PM
Truckshop's Avatar
well that sucks. maybe charlie or someone else will chime in. i didn't do anything special for my buddies truck. although his was an 04 like mine. maybe because its a os for a 2500.
