Errors when trying to do OS upgrade and new calibration
Old Feb 2, 2014 | 02:32 PM
black00chev's Avatar
Slowest turbo build ever!
Default Errors when trying to do OS upgrade and new calibration
So when trying to perform a full reflash I get this...
"Cannot create file C:\Program Files(x86)\EFILive\V7.5\Configuration\PCMLocks.ini . Access is denied.
And when trying to flash just a calibration I get this...
"The file's operating system number: 12212156, is not compatible with the PCM's operating system number: 12205612.
A calibration reflash is only permitted when both operating systems are compatible."
Im assuming the second error is because the PCM I have doesn't match the original PCM used. But I have no idea about the first one.
Old Feb 2, 2014 | 03:06 PM
1FastBrick's Avatar
Custm2500's Rude Friend
What exactly are you trying to do?
Looks like your trying to flash an older 99 camaro calibration over a 2000 silverado calibration.
Old Feb 2, 2014 | 10:01 PM
Well was trying to flash in an 02 OS upgrade and new tune but I think the PCM I have might all ready be an 02 and wont let it work. Even if I try to just flash in the tune it wont work.
Old Feb 2, 2014 | 10:45 PM
1FastBrick's Avatar
is the new PCM already licensed to your cable? Is this a V2 your using or something else?
Old Feb 2, 2014 | 11:10 PM
New pcm is licensed since I tried this one time before, decided to try again and posted the errors this time. Yea using the V2 in pass through mode.
Old Feb 2, 2014 | 11:12 PM
GMCtrk's Avatar
Is the PCM locked? That cal is already 02 OS so no need to change it.
Old Feb 3, 2014 | 12:00 AM
1FastBrick's Avatar
to change the OS you have to do a full flash. thats why you got the mesage whn just trying to write over.
The first one sounds like it's locked???
Old Feb 3, 2014 | 12:05 AM
1FastBrick's Avatar
Under the Silverado calibrations on tune file depot
12212156 shows up under 2002 Silverado
12205612 I only see under 2000 Silverado
Are you bench flashing this or is it in the truck when your attempting to flash it?
Old Feb 3, 2014 | 08:18 PM
LSX Power Tuning's Avatar
Are you running the latest update with EFI Live? I full flash pcm's almost every day without any issue. I just did a couple today actually. I use the 2002 OS 12212156 in 99-01's all the time, just full flash them the first time and you will be good. Did you try flashing it with V8 or just in V7.5?
Old Feb 3, 2014 | 09:18 PM
Got everything worked out... A VERY simple fix that Justin solved via email.
It was a permissions issue with my laptop. Right click on the tune tool, run as administrator, and problem solved. Anytime I want to actually flash in a new tune Ill have to go that route. Otherwise there are no issues.
Texas5.3_1251
Mar 5, 2016 08:10 PM
Alco
Oct 4, 2015 06:58 AM
Chevy305
Sep 28, 2015 09:21 PM
Raiderjim
Sep 28, 2015 10:37 AM
sTNT971
Sep 26, 2015 06:27 AM
