Engine Torque management??
Old Feb 7, 2006 | 09:10 AM
It looks like you would have to change the abuse mode too??
Old Feb 7, 2006 | 09:14 AM
FILE's Avatar
That is right.. Don't forget about abuse mode...
Old Feb 7, 2006 | 09:25 AM
I am referring to the abuse mode tab under the engine>tq management. Is that the same spot you are talking about? So do I need to set the rpm>high and the speed<low so that the abuse mode test will not run?
Old Feb 7, 2006 | 09:55 AM
white1's Avatar
Im not looking at it right now, but I thought you could just disable abuse mode.
Im not sure about the torque stuff youre refering to. I know what you are talking about, but not sure. I think I was tuning under the basic, when I switched to advanced is the first time I saw that, so Im not sure yet.
Old Feb 7, 2006 | 09:58 AM
Under the tranny tm settings you can disable the tm. But the engine tm has no option to enable or disable. I just want to make sure that I adjust the correct settings.
Old Feb 7, 2006 | 11:02 PM
Okie5.3's Avatar
here are some links of screen shots to help reduce/eliminate TM.
http://bigdogfrank.koehlerpro.com/images/engabuse.jpg
http://bigdogfrank.koehlerpro.com/images/enginetm.jpg
http://bigdogfrank.koehlerpro.com/images/maxtq.jpg
http://bigdogfrank.koehlerpro.com/images/tcs.jpg
http://bigdogfrank.koehlerpro.com/images/tqred.jpg
http://bigdogfrank.koehlerpro.com/images/trans.jpg
Old Feb 8, 2006 | 07:03 AM
That is pretty much what I have now. I made the changes and loaded them last night. It now breaks loose in 2nd, so that was definately the problem. Thanks guys.
Gadgetized
Aug 21, 2020 03:14 PM
TAPyvehc93
Jul 23, 2017 10:54 PM
1979rs/z28
Sep 23, 2015 08:39 AM
OLD BULL
Aug 1, 2015 05:00 PM
