engine light
Originally Posted by NegraRCSB2X4auto
Man that freaken light came back on bankone banktwo lean. Could this be a damn tunning problem I'm thinking of getting a whole different tune from someone else.
Unfortunately you need a guage to get an accurate fuel pressure reading...I believe that there's a port on one of the fuel rails that it will connect to. As for checking for vacuum leaks, easiest way is to get some carb or throttle body cleaner and spray around the areas that a vacuum leak may occur (intake manifold, throttle body, vacuum lines, etc.). If the engine idle changes (it will usually raise), then you have located the source of the vacuum leak. Also, check and make sure that the air intake tube is nice and tight and not leaking anywhere.
Here's a question would my check engine light be on instantly if i had a vacuum leak every time i turn on my truck. I erased the code this morning before i went to work and when i got out of work and turned the truck back on the light did not come on. Or is that normal and also how can i test to see if my MAF sensor is working properly.
ARC
57
Feb 21, 2022 10:54 AM
tweeder
Sep 18, 2015 11:02 PM
bsgiffor
Jul 19, 2015 11:14 AM
