electrical issue i need some help with
Registered User
this has been a problem since i bought the truck, its only recently started to happen often. when driving the dash needles just cut off as well as the odometer. for no reason really. im thinking its a grounding issue, anyone have any other ideas what could be causing it?
the pic below the dash just cut out while going down the road. sometimes it cuts back on for no reason as well
Check the ignition switch on the left side of the steering column. It controls voltage to nearly everything electrical on these rigs. That $30 part cost me a transmission when it quit sending signal to the tranny and I burned up my second 60e. Might not be your problem but cluster light/gauge cutout is a classic symptom of a faulty one. Google it..
Hope this helps...
This is the part:
Hope this helps...
This is the part:
The fourth and fifth pins from the left on the bottom row look questionable through the internet, the two right most ones on the top row, too. The second one from the right on the top even has a piece missing. From what I can see zoomed in as much as possible. You are at the point where you might as well try re-wetting the joints, in my opinion.
