Electric fan Tuning!!!
Old Apr 22, 2007 | 10:53 PM
ShakeNBake's Avatar
Default Electric fan Tuning!!!
got my 05 electric fans on and am working on the tuning...
using hp tuners went to aux fans on at 180 of at 169 second fan on at 179 of at 168 but the problem is that the fans are never coming on. now the nelson fan harness to check my connection pulled the pcm harness of and grounded pin 42 to the battery and the fans kick on so i dont know what i have done but wanted to know if anyone knows what i am doing wrong with the tuning to make it to where they will not come on by the pcm telling it to i no that it has to be in the tuning because it does work if i ground the connection out.
thanx in advance
zach
Old Apr 23, 2007 | 12:26 AM
Kingpimp's Avatar
I used the box "two fans" instead of auxfans on my truck.
Old Apr 23, 2007 | 12:31 AM
ShakeNBake's Avatar
i tried both ways and still it is a no go
Old Apr 23, 2007 | 09:38 AM
Tootall's Avatar
https://www.performancetrucks.net/fo...d.php?t=377292
http://www.monodax.com/forums/tunerc...-98-chevy.html
Old Apr 23, 2007 | 11:06 PM
gmforlife's Avatar
I have aux fans on mine and they work fine. Double check the pin 42, make sure it pushes "ALL" the way in, when i did my tranny swap, i forgot to push the pins all the way in and i had problems read VSS. But that's what i would do, sometimes those pins can be a bitch to push in, make sure they make a little click noise.
Old Apr 23, 2007 | 11:19 PM
truckmann's Avatar
The second fan temp settings will not do anything unless you have a harness with 2 wires to the PCM and I have not heard of anyone doing that. I am guessing you have a 160* thermostat if you are wanting to try and run that cool and I would think that even if you do have a 160* stat with those settings your fans will probably run non stop when you get them working. From what I have heard you may want to set those fan settings a bit higher. Of course you can work that out after you get them working.
Old Apr 23, 2007 | 11:20 PM
gmforlife's Avatar
I was just gonna suggest the same thing
Old Apr 28, 2007 | 04:46 PM
bigredexpress99's Avatar
And now you have...me!! Here ya go.....start @ page 4 for the good stuff.
Old Apr 28, 2007 | 05:04 PM
Wilde Racing's Avatar
How do I change this text
the nelson harness will not work with both fan controls in the pcm. you only get one pcm fan setting and one a/c clutch enable.
I'd suggest sence you have a 04 (which can support both fans, using pin 42, and 36 I believe), that you rewire the nelson harness so that it has two ground controled relays and not just one.....
5.3Okasai
Mar 9, 2022 01:07 PM
noproblems209
Aug 10, 2015 06:57 PM
Ketis
Jul 23, 2015 12:37 PM
