Banned
Quote:
Here is the number #15216042 , just checked gmpartsdirect.com it has went up since I bought mine .Originally Posted by BlownHD
You wouldn't happen to know the harness part #???
If you happen to find a cheap source for these please post it up will you .
Quote:
I think GMpartsdirect.com and I have a couple of more places that have it but can't remember them right off hand .
And yes the harness is part of a forward fog light assembly , so if you don't have fog lights and you want them you get two for the price of one .
My point wasn't about the fans pins - there are several 4wd connections to the pcm. If you switch to a 'vette os you'll most likely loose the ability to have 4wd. If I get bored today I'll look through the charts and see what actually goes where.Originally Posted by HD6.0l
I looked at some schematics and pin 42 and 33 are there in 02 so the PCM should trigger both just fine (2wd and 4wd) .I think GMpartsdirect.com and I have a couple of more places that have it but can't remember them right off hand .
Hello Dave
Quote:
I don't think that would be a problem, as both trucks and the vettes used OS 12212156 in 2002.Originally Posted by jknox
So could I upgrade to an 02 OS and maybe solve the problem of only having one fan relay output.
Banned
Quote:
http://img.photobucket.com/albums/v7...ring3relay.gif
Or this,Originally Posted by Tootall
you can make your own harness http://img.photobucket.com/albums/v7...ring3relay.gif
This works just like the factory harness , A/C on Low (2 fans) , temp reached 210* Low (2 fans) , High temp (over heated 240*+) High (2 fans) .
Quote:
what are the rules for that one, and how does it work?Originally Posted by HD6.0l
Or this,
im planning on getting ls1 fans with nelsons harness for 03 2wd, whats needs to be done for fans to work? is there any other parts that i need?
Registered User
ok maybe I have overlooked it some where but here goes. I have a 2000 Z71 Tahoe...OLD BODY STYLE....5.7 engine. I got the 05 oem fans and puchased a Nelson harness.....they failed to tell me that their harness was only for the new body style....I can make it work but need to know if there is a pin I can use other than 42 because my blue PCM connector only has 32 pins. Silly me, I believed their plug n play talk. I know that it is only a ground but would like it to be temp operated.
Quote:
do some reading over here . . . . he explains it!Originally Posted by nyaiad
http://www.monodax.com/forums/tunerc...-98-chevy.html
