EGR Delete - removed checks in HPT Do I Need to Do Anything Else?
Old Jun 3, 2008 | 02:52 PM
FL-Pirate's Avatar
10 Second Club
Default EGR Delete - removed checks in HPT Do I Need to Do Anything Else?
To make a long story short - after un-installing my RADIX (Magnacharger) I could not re-install the EGR tube into the stock manifold due to the tube being cut for the Maggie. I used a plug and exhaust block-off to delete the EGR. I've removed all the EGR related checks via HPTuners. It seems to be running fine (back to stock) so is there anything else I need to know about the EGR delete? Will this cause a rich or lean condition?
Thanks!
Old Jun 4, 2008 | 12:38 PM
454SuperSport's Avatar
make sure you go in the spark control section and zero out the EGR correction table. also in the general section set the EGR master switch to disabled.
Old Jun 4, 2008 | 12:41 PM
FL-Pirate's Avatar
10 Second Club
Thanks! I did miss the Spark Control > Misc > EGR Correction Table.
Thanks again!
Stainless Works
Apr 10, 2016 04:34 PM
AkSSS
Mar 29, 2016 11:03 PM
JFortner5
Aug 20, 2015 06:13 PM
Stainless Works
Aug 4, 2015 12:56 PM
