EFiLive vs HPT ... owners of both, I need opinions
#32
I noticed on the EFILive Forum you had you question under the Bidi section. Today was the first day I ever looked at that section. If you re-post it I would use the Tuning/Petro Gas/gen III section.
#33
GMC, sorry i couldnt get out there today to resplice the two wires I cut (11 / 17 red ) so i didnt get a chance to test the A/C voltage. I will definitely do it tomorrow though. By the time I dropped my daughter back off at her mom's house, it started raining so i couldnt do those two connections to get myself back to ground 0 again. Ill definitely post my results tomorrow afternoon sometime... Like around 4PM eastern when i get home from work!!
#34
http://forum.efilive.com/showthread....-PCM-and-EFans
EDIT: Oh ok i see what youre saying, that spot has more forums within that specific forum heading
#35
Bet you never expected these results LOL..... 0volts on all three tests...Key on engine off, Engine on NO A/C, Engine on A/C on.
And yes i did reconnect 11 and 17 back to the PCM again lol
#36
Its gotta be something to do with the HVAC system module...its shorted out somewhere because the PCM thinks the A/C is on all the time, which is why im getting constant fan activity.
#38
So meaning I must have a short in the controls inside the cabin!? I can try pulling the dash and pull the heat/AC control unit out!?
Or better yet is there one main HVAC system that reports to the PCM? Cause since im not getting a voltage reading on any of the pressure sensors there must be an intermediate device that they report to and the device would then report the values to the PCM!?!?
#39
If you go back to the a/c control schematic, it will show you that it comes through one of the wires that you disconnected. I have a feeling this may possibly be an EFI-live problem. I don't use EFI-live so I can't say for sure.
#40
Damnit, Im assuming you mean Pin 55!? A/C signal request? Yeah i definitely pulled that one..actually i pulled all the A/C ones out! Weird enough, the clutch cable still had a live ground connection to it even when the key was off. Man something is royally screwed. I want to blame it on EFilive but i think this is mechanical/electrical to be honest. In every case that i read on EFiLive where people had this issue, they were still able to use the Bidi controls to manually turn the fans on and off which I cannot do. It's like it is getting its ground from somewhere totally different, and forcing the connection to 42b and 33r and 43r (A/C clutch signal)
Also the fact that im getting no volt signal from the low or high pressure switched either
