EFILive V2 questions
Old Feb 18, 2009 | 03:24 PM
53RUSSELL's Avatar
Default EFILive V2 questions
I just update from a V1 to V2. I have updated my plx gauge to read off the EFILive serial port. I want to know witch pid need to use for the VE map in EFILive for the A/F gauge.
Thanks for the help.
Old Feb 18, 2009 | 05:36 PM
Mort's Avatar
Plug into the A1 ADL on the bottom of the V2 ( see back side for location of ADL port) with the supplied connector wired to your PLX.
Select the External Analog Voltage 1 (EXT.AD1) PID.
Select the Wide Band AFR 1 - PLX (CALC.AFR_PLX1) PID.
I think that should do it.
If you want to do AUTO-VE :
Select the Base Efficiency Numerator 1 - PLX (CALC.BEN_PLX1) PID and the Engine Coolant Temperature (SAE>ECT) PID and read up on the Auto- VE tutorial. Also good to know the Commanded Air Fuel Ratio (GM.AFR) PID so you can compare your actual AFR with your Commanded AFR.
You can select other PIDs you find interesting such as Throttle Position, RPM, Spark, IAT, MAP, KR up to 24 channels. Any more will greatly reduce the information collected.
Good luck.
Old Feb 18, 2009 | 10:14 PM
53RUSSELL's Avatar
yea I know that stuff. I just up-dated to v2 last week. I converted my plx gauge to a serial port like they shown in this thread http://forum.efilive.com/showthread.php?t=7726This was the pid i was looking for VE map (BEN Factor Bank 1, Serial Wideband, LS1 style (calc.ben1))
Thanks for the help
Old Feb 19, 2009 | 06:09 PM
Mort's Avatar
I am not sure what you are looking for? Will one of the MAPS in the MAP Folder that comes with EFILive work?
{B0101} Main VE - PLX WO2 BEN (2Bar).map
{B0101} Main VE - PLX WO2 BEN.map
Old Feb 20, 2009 | 09:58 AM
53RUSSELL's Avatar
It's cool. I got working.
Old Feb 20, 2009 | 10:44 AM
BlackGMC's Avatar
Resident Retard
I did not think they had the pass threw logging available yet for serial input, only black box logging, meaning you would have to log with just the V2 scanner without your laptop. Then download it and view it? Have they updated this so you can see it real time on your laptop now?
Old Feb 20, 2009 | 04:22 PM
53RUSSELL's Avatar
You can log with V2 just like you did with the V1 with the laptop. I just got this a week go and there alot of things you can do now. BlackGMC sent you a pm.
Old Feb 20, 2009 | 11:51 PM
53RUSSELL's Avatar
Corey,
if you have any more questions let me know.
JordanH
Dec 25, 2015 08:32 AM
Tydriver
45
Oct 23, 2015 09:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
