Efilive ???
Old Nov 19, 2016 | 02:18 PM
  #31
DrX's Avatar
DrX
Originally Posted by crashmymax
Just purchase EFIv2. I want to learn how this stuff works. Would be nice to look at other peoples tunes. So how do you look at them? I downloaded trxmxzx tune and it showed up in scan and tune but what do you do with it from there?
If this question does not belong in this thread just let me know.
Double click on it, then click Edit on the left.
Old Mar 19, 2017 | 09:12 AM
  #32
trxmxzx's Avatar
13 Second Truck Club
So question- B6614 does that need to be changed to zero to get rid of a rpm (rev limit) trying to shift a 2005 ppl Tahoe and it hits 5800rpm and it cuts everything out spudders ( sounds like rev limiter) everything is above 6100rpm (fuel cut off) I found this morning going through the tune
Old Mar 19, 2017 | 11:48 AM
  #33
Gadgetized's Avatar
What is your rev limiter set at and what RPM are you logging?
Old Mar 19, 2017 | 12:42 PM
  #34
trxmxzx's Avatar
let me get back to you little later- out with the wife and kids away from laptop
Old Mar 19, 2017 | 08:22 PM
  #35
trxmxzx's Avatar
6100 limit is set
6050 to enable fueling again
shifting at 5800 just because it's a stock trans -
if I recall still haven't been able to get my laptop booted up-
Old Mar 20, 2017 | 02:19 PM
  #36
Gadgetized's Avatar
In order for a shift to be commanded an RPM and speed BOTH need to be met. If you have your RPM met, but you are not going fast enough, the shift will not take place.
Old Mar 20, 2017 | 02:38 PM
  #37
TXsilverado's Avatar
efi live arrived today. I'll be keeping an eye on this thread.
Old Mar 20, 2017 | 08:42 PM
  #38
trxmxzx's Avatar
correct- I'm commanding at 38 mph shift at 5800rpm
if calculations are correct at 45 mph I'll be at 5797 rpms
i couldn't remember if it had to be within 5 mph of each other
Old Mar 20, 2017 | 08:44 PM
  #39
trxmxzx's Avatar
Old Mar 20, 2017 | 08:48 PM
  #40
trxmxzx's Avatar
This is the table I was curious about
