EFI Tuners check my work, 4L80E swap tune
#71
On my 80E , I did the TransGo kit myself , there were no washers involved , just drilling the first , second , and third shift holes larger for more kick in the shift , there is a spring that is behind a valve (located close to the front left hand side looking rear to front , held in by E clip) that ups some pressure but not a lot (4L80E slightly different than a 4L60E) . I kept stock line pressure and 0ed the shift times in 1-2 , 2-3 , and 3-4 .
If you are in SD , there is a table you need to adjust in {E0104} (P0101, 102, ad 103 to "NO") that ups the pressure when the MAF fails .
#74
Originally Posted by 1SlowHoe
Hmm. Whats all this talk of washers all the time then?
I'm not SD. I just added a ton of tq mng to the part throttle and pulled some line pressure. I'm gonna go try her out.
#77
Probably not , not with the 80E , U-joints , back rest of seat , but would not do for to long .
Mine with the "firm" holes drilled felt like someone running into the rear of the truck every time it shifted , got tired of that , shot peened the holes and did "normal" hole size just right firm and fast .
With the TransGo you can do "soft" , "normal" , and "firm" just by drilling hole sizes , larger hole more firmness , when I say larger I mean just a few thousandth .
#78
I can deal with the firmness for now but is it going to damage anything?
#80
So how hard is it to get to this plate I neede to shot peen and drill?
Is there a how to or pictures anybody knows of?
