EFI live trouble- wont log DTC's
Old Mar 4, 2011 | 03:02 AM
99LsSilverado's Avatar
Just another suggestion is to make sure that you are connecting with the right controler, which should be the GENIII LS1 99-08 PCM. It is under select controller under the file tab
Old Mar 4, 2011 | 05:00 PM
Mangled03gmc's Avatar
Baltimore Whore
All the connections are legit, I have used this many times over to log with.. It just will not let me actually scan DTC's or even log anything.. Just connect..
Old Mar 4, 2011 | 08:19 PM
kbracing96's Avatar
It's only connecting to the V2 its self and not the truck, that's why everything is grayed out. Check and make sure the OBDII port fuse (cig fuse) is good and when you plug the V2 into the OBDII port that it powers up (not connected to the laptop) . You should plug it into the truck first and then the laptop anyway.
Old Mar 5, 2011 | 05:07 PM
Baltimore Whore
Awesome, you the man. That was it thanks
Old Mar 5, 2011 | 05:38 PM
1SlowHoe's Avatar
Destroyer of Transmissions
It was a blown fuse?
Old Mar 5, 2011 | 05:51 PM
Baltimore Whore
Yes it was the exact fuse KB said.. Thanks btw for trying
Old Mar 6, 2011 | 11:11 AM
kbracing96's Avatar
Good deal! Been around the block a time or two with these things,
Wolftrk99
Dec 3, 2015 08:12 PM
murderedSS
Sep 27, 2015 10:16 PM
lxcoupe
Sep 23, 2015 12:11 AM
creekrat
Sep 10, 2015 12:59 AM
