Efi live fuel pressure tune question
Old Oct 28, 2010 | 10:02 AM
Mrgoodwrench3's Avatar
Default Efi live fuel pressure tune question
I have my 2007 Silverado 5.3 LY5. Finished the cam head swap about 5 weeks ago. Had Justin from Blackbear retune it. It was fine until a few days ago. Now when coming to a stop the idle will go down to 500, jump back uo to 1200, drop down and stall. If I give it throttle it will stay running. I do not have any codes in the ECM or FPCM. MAF and Throttlebody are new. No vacuum leaks.
I made no changes to the truck after the tune. This just started one morning.
Question is, my fuel pressure at idle is 42psi. Spec is 52/62. The desired matches the actual on my Tech2. Is this something that is changed during the re-tune? I put a gauge on the fuel rail and it is 42psi. Seems low. According to what I know fuel pressure should not change under load, should remain constant, right?? My fuel trims are normal and it drives fine on the highway.
I would think the desired would be higher??? Or is my pump going out?
Old Oct 28, 2010 | 01:12 PM
Mike@Diablosport's Avatar
LS1Tech Sponsor
Probably want to post this in the GM section...
Old Oct 28, 2010 | 01:25 PM
00ChevyScott's Avatar
Wearin' da big hat
Fuel pump might have ate the dust.
Old Nov 23, 2010 | 09:05 PM
mike058's Avatar
Highway hauler
Check your injector pulse width, i'll bet it is higher than normal. Plan on changing the fuel pump. Double check the harness at the pump to make sure it is not melted, increasing resistance.
Old Nov 23, 2010 | 09:53 PM
MikeGyver's Avatar
Also monitor voltage. Low voltage will cause all kinds of heck.
Old Mar 20, 2011 | 02:58 PM
my bad 98's Avatar
Registered User
I would think that the fuel pump might be going out because four of my friends own silverado pickups and three of them have had to get a new fuel pump and the one that hasn't had to change his yet has already ordered one because his is starting to spit and sputer. Oh and also i would check the fuel filter.
Last edited by my bad 98; Mar 20, 2011 at 03:03 PM. Reason: remembered something else
black00chev
Jul 31, 2015 04:33 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
slowlsx
Jul 13, 2015 04:18 AM
