EFI Live Cos3 and closed loop?
Old Jan 29, 2011 | 09:46 PM
02'Z71ONDUBZ''s Avatar
Default EFI Live Cos3 and closed loop?
Is it ok to run the engine in closed loop on a cos3 2bar tune? My tuner has me set up running off the trims right now, but I just read in a tutorial not to run in closed loop with a cos3. What does it mean?
Old Jan 30, 2011 | 03:05 PM
JoeyGC5's Avatar
You can run with LTFT enabled, but it is a pita to get the boost control to work correctly. With the COS setup enabled correctly (correct temp control settings and LTFT disabled) the fuel trimming should work fine and there should be no issues.
Wolftrk99
Dec 3, 2015 08:12 PM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
94f150
Sep 28, 2015 05:28 PM
