ECM setup for flex fuel
Old Mar 24, 2013 | 11:57 AM
  #31
Ender06's Avatar
I suppose gas scale. They know nothing of e85. That's why I've got no local tuning help
Old Mar 24, 2013 | 12:00 PM
  #32
GMCtrk's Avatar
If you're running 10.8 on the gas scale, you're tune is all screwed up. That's an AFR of somewhere around 6.9 or 7 on the ethanol scale. You need to be around 10:1.
I think you need to just run it on gas for the time being until you get a wideband and do this thing properly.
  #33
Ender06's Avatar
In my area, if its not a diesel, don't hope for any extensive help
Old Mar 24, 2013 | 12:08 PM
  #34
Ender06's Avatar
OK how does changing the Stoich in the ecm work. Is it not set up for gas?
Old Mar 24, 2013 | 12:51 PM
  #35
MustangPunk's Avatar
If HPtuners, goto Engine, fuel tab, and under general tab... under the heading Air Fuel Ratio you'll see Stoich AFR.. EFI Live should be close.
Older OS's just show Stoich xx.xx, just change that accordingly, some newer ones may have flex fuel tables, so you can just put the desired Stoich in each cell across the table.
The PCM doesnt care what fuel you're using, it's your job to make it know what Stoich is for your fuel.
Old Mar 25, 2013 | 12:07 PM
  #36
Area47's Avatar
OK well the mixture came out to about %81 ethanol. But I have a problem. With Stoich set to 10.4 the fuel trims are dead on. I opened injector pulse by 4% also. Power is definitely there, but my EGT's are HOT. Cruising at 60-65 they're running 1300 and wot it has hit 1550 but I have quit there in fear of it climbing much higher. Normal gas tune runs about 1150-1200 cruising and only see 1500 towing heavy loads. What is causing the heat?? I was under the impression ethanol burnt colder. Thanks guys
chenge your injector scaling back to stock. do NOT change it. just the stoich as previously stated.
The truck is back to n/a. Has been for quite a while. I should've updated my SIG, sorry. Anyway the local Dyno has a "tailpipe" wideband that's reading 10.8 cruising, but how accurate are these things that far back in the exhaust?
on 1.00 scale gasoline vs e85 the stoich lambda is the same. running an actual 10.8 afr at the o2 sensor is hosing the cylinders down. this is bad.
where is your egt probe?
05GMC4.8
Aug 7, 2015 09:55 PM
RS/SS 4.8
Aug 2, 2015 11:03 PM
MWRitter
Jul 27, 2015 09:41 AM
Closer_2001
Jul 21, 2015 03:25 PM
lxcoupe
Jul 21, 2015 02:12 AM
