E85 changed stoich but VE way off
Old Aug 19, 2013 | 09:43 PM
MustangPunk's Avatar
Originally Posted by kbracing96
Ok, let me get this strait... You changed stoich to 9.8 (which should have made you really rich since you're really only have probably E60-65 or so in it since you still had a couple gallons of gas in it. THEN you TOOK 20% OUT of the VE to lean it out and now your lean??? You should try putting your VE back to stock and then try 10.5-11 Stoich and adjusting it up or down till you can get your STFT and LTFT back in line. You will then have to re-adjust it down next time you fill up as you get closer to actual E85.
BTW, You can buy the Cadillac sensor and pig tail off Ebay for about $100 and enable the ethanol tables in your stock tune and have TRUE FF. I just did this with my Cruze. Worked AWESOME!
I took 20% to get back to lambda, it was just really lean on cold start (60 F) this morning. I will do as you suggest, I just didn't think it would be that far off but I'm sure it is because it isn't true e85 yet like you said. I'm trying to find that spreadsheet Atomic made.
That's a new part price? If so that's dirty cheap, those sensors should be full of diamonds based on some of the prices I've seen charged for them.
Old Aug 19, 2013 | 10:04 PM
Atomic's Avatar
I have a gauge for that
https://www.performancetrucks.net/fo...ksheet-500126/
Old Aug 19, 2013 | 10:36 PM
Thanks, I just found it too, a few minutes before you posted. Yeah, I did the math (well you did :p)and Kyle damn near nailed it. I'll load the gas VE that was pretty spot on, try 11.1:1 as stoich and see how it is. I didn't realize how much even a 3-4 gallons (possibly even more)of gas could effect it, just being naive I guess. Thanks guys.
Old Aug 19, 2013 | 10:53 PM
oakley6575's Avatar
Originally Posted by MustangPunk
Starting sometime in '05 for the '06 models GM switched to virtual flex fuel sensor. There is no physical sensor, it's all in the PCM. It uses the fuel level sensor, purge vent, fuel trims, and probably some mystical crap to determine stoich haha.
Oh okay. Good to know. I thought that started in the NNBS trucks
Old Aug 20, 2013 | 05:03 PM
BLK02WS6's Avatar
9 Second Club
Cause it wouldn't make a difference if he doesn't have the ethanol content sensor in the fuel system from the factory.
Not true - 05 and 06 OS's use a virtual flex fuel setup - no ethanol content sensor. You can put a flex fuel OS in a non-flex fuel vehicle and you don't need a sensor...
Old Aug 20, 2013 | 05:05 PM
oakley6575's Avatar
This was already covered by mustangpunk
Old Aug 20, 2013 | 05:06 PM
BLK02WS6's Avatar
9 Second Club
I already have a 2 bar OS and don't really feel like spending the credits. I looked at a '06 L59, all the same tables except, it would be neat if it was actually enabled on non flex OS's.
One of the advantages of EFILive - no credits... I would think it would be worth it to have flex fuel capability! I have one ready to plug into my wife's 06 Tahoe should I ever have the need/availability for E85...
Old Aug 20, 2013 | 05:07 PM
BLK02WS6's Avatar
9 Second Club
Yeah... well, I replied to yours before I saw his...
Razor
Dec 1, 2015 10:46 AM
slowswb
Sep 5, 2015 02:27 PM
Gmc_sierra
Aug 21, 2015 10:08 AM
Jake75
Aug 21, 2015 09:13 AM
Sexyrado327
Aug 2, 2015 04:08 PM
