E85 changed stoich but VE way off
Ok, let me get this strait... You changed stoich to 9.8 (which should have made you really rich since you're really only have probably E60-65 or so in it since you still had a couple gallons of gas in it. THEN you TOOK 20% OUT of the VE to lean it out and now your lean??? You should try putting your VE back to stock and then try 10.5-11 Stoich and adjusting it up or down till you can get your STFT and LTFT back in line. You will then have to re-adjust it down next time you fill up as you get closer to actual E85.
BTW, You can buy the Cadillac sensor and pig tail off Ebay for about $100 and enable the ethanol tables in your stock tune and have TRUE FF. I just did this with my Cruze. Worked AWESOME!
That's a new part price? If so that's dirty cheap, those sensors should be full of diamonds based on some of the prices I've seen charged for them.
Oh okay. Good to know. I thought that started in the NNBS trucks
Not true - 05 and 06 OS's use a virtual flex fuel setup - no ethanol content sensor. You can put a flex fuel OS in a non-flex fuel vehicle and you don't need a sensor...
One of the advantages of EFILive - no credits... I would think it would be worth it to have flex fuel capability! I have one ready to plug into my wife's 06 Tahoe should I ever have the need/availability for E85...
