E38 shutdown problems ...
Hey gang, long time no see here. I have an 07 GMC Yukon Denali XL with the 6.2L engine. For some reason, after driving for an extended period of time at somewhat high speeds ( 70 - 80 MPH), and coming to a stop, the truck will die when it reaches idle. The RPMs will start to bounce and surge until it finally goes to 0 and shuts off. I have been scanning with EFI live, and trying to pinpoint the issue. So far, I have replaced:
* Fuel pump
* both O2 sensors 1 (bank 1 and 2)
* MAF sensor
* crankshaft and cam sensors
The strange thing is, it doesn't throw any error codes when this happens. It's as if the PCM has no idea that there is an issue.
Another strange thing. Im seeing that the cam phaser control circuits for bank 1 on the intake side, is the only one that is NOT in a failed state.
* Intake Cam Phase Bank 1 Control Circuit: Passed
* Intake Cam Phase Bank 2 Control Circuit: Failed
* Exhaust Cam Phase Bank 1 Control Circuit: Failed
* Exhaust Cam Phase Bank 2 Control Circuit: Failed
Even with these failed states, there are no SES lights on and no pending codes either! What the heck am I missing?
Oh also, when the truck dies at idle after the long drive, it is almost impossible to get it started again. It ACTS like it's a vapor lock issue. I have to floor the pedal, to kill the injectors, crank the engine once, then release the pedal, and crank it again to get it started. Sometimes I need to repeat this process to get it started again... or just wait several hours.
Thanks all, appreciate your time and wisdom as always...
* Fuel pump
* MAF sensor
Custm2500's Rude Friend
Just did an 07 Tahoe a few months back that would intermittently run like garbage. and only got worse. When it did run correctly, everything checked out. Almost seemed like it wasn't getting fuel.
Finally ended up put an ECU in it and all is well except the Catalytic Converters that it killed... Owner still trying to source a reasonable set.
I was afraid of that... I guess it would be the next cheapest thing to replace lol. Thanks for the feedback, I wish GM didnt complicate these trucks... I miss the LT/LS days when the trucks just worked...
We dropped the tank and replaced the pump with a known good pump to rule it out.
Dropped the catalytic converts to make sure they weren't clogged causing excessive back pressure.
All the sensors worked properly when it was running correctly too.
Mod with training wheels
Unfortunately, AT least on the one I worked on, the fuel pressure starts to drop as a secondary Issue.
Twentyhurtz
05-26-2013 03:06 PM
ivan_key
23
07-26-2012 04:33 PM
