E-fan swap. No auto turn on, can command on
Old Aug 25, 2017 | 08:22 PM
FullOutPwr's Avatar
Default E-fan swap. No auto turn on, can command on
I finished up the e-fan swap today. I let the coolant temp (per the ECT on scanner) get to 241* before manually commanding the fans on. I could command both fans on, both individually and as a pair at the same time. This leads me to believe there is no wiring/fan issues.
Can someone see if I messed something up in the tune file? OS is 9379910.
File Type: hpt
Old Aug 25, 2017 | 09:13 PM
1FastBrick's Avatar
Custm2500's Rude Friend
try setting a disable speed higher than the enable speed.
Old Aug 29, 2017 | 05:14 PM
FullOutPwr's Avatar
Meant to reply earlier- that was it. Thank you for the catch!
