e-fan harness
Old Jan 22, 2012 | 11:57 PM
brent1976's Avatar
11 Second Club
Default e-fan harness
It's cold, and I'm bored and want to do something to my truck.
I have a 99 with an 02 pcm in it. I have called bb, about their 2 pin efan harness, and they said it wouldn't work in my truck. I have hptuners, and there are options to turn on fans, and control them. Can I re-wire my nelson harness to control the efans with the pcm, and actually control them, or do I need them hooked to the ac wire.
Old Jan 23, 2012 | 12:03 AM
nonnieselman's Avatar
Ive got a write up on how to do the harness.
If i knew exactly how your harness was setup i could walk you thru how to repin it.
Old Jan 23, 2012 | 10:05 PM
brent1976's Avatar
11 Second Club
I'm pretty sure I've seen your write up a year or 2 ago, but forgot who did it ,and couldn't find it yesterday. I will search again now that I know it was you.
Old Jan 24, 2012 | 12:38 PM
This is one i just did recently.
https://www.performancetrucks.net/fo...-101-a-494123/
Lemme know if you need some help sorting it out
Old Jan 24, 2012 | 12:42 PM
Ferocity02's Avatar
On OBS trucks, can the PCM be used to activate the fans when the AC is on? Is that what pin 33 is for? I have the one fan tapped into the AC clutch signal right now (Nelson harness).
Old Jan 24, 2012 | 12:55 PM
I cant rem about the OBS pcms.. but i rem seeing something in there about fan options
Old Jan 24, 2012 | 01:53 PM
TIM Z's Avatar
11 sec. Truck Mod
Hows the 14 bolt coming along Brent?
Old Jan 24, 2012 | 08:57 PM
Formerly 99-2door-08/30/2010
If you have a harness set up to tap into the AC clutch wire you have to change the polarity on the relay signal to hook it to the PCM.
Old Jan 24, 2012 | 09:02 PM
brent1976's Avatar
11 Second Club
#GM 14-9.5
I ordered one of these covers from blownchevy, and picked up the u-joint last week, and I've got new rotors in the garage. A couple of my buddies are itching to work on something since it's been cold, so it's going in soon.
Old Jan 24, 2012 | 09:06 PM
brent1976's Avatar
11 Second Club
I understand the diagrams, but the only one I can find is the one that hooks to the ac. I know I have seen one that has 2 connections to the pcm instead.
