E-Fan guys get in here (2003 silverado)
Old Jan 23, 2011 | 08:43 PM
  #31
Cook's Avatar
It was turned on, i use to have a clutch fan, when i gave him the pcm i had him turn it on, i know its turned on because of the codes. they wouldnt be there if it wasnt turned on
Old Jan 23, 2011 | 08:44 PM
  #32
Cook's Avatar
ok i thought i had it. i figured i would have the middle relay's coil activated by the + AC trigger AND the pin 42 ground signal. that way it would only activate when both were on. but...i ended up with this
that way the left fan can be on by itself, but when the AC is turned on BOTH have to turn on, even if PIN 42 isnt energized.
Old Jan 23, 2011 | 08:51 PM
  #33
Cook's Avatar
alright hopefully we can get some others in here to chime in. im signing off for the night. thanks for all the help
Old Jan 23, 2011 | 08:56 PM
  #34
MikeGyver's Avatar
Yeah, that would still need a third relay to power 87a in the left relay, the A/C clutch wire would not be able to supply enough power for a fan, too.
Old Jan 23, 2011 | 09:30 PM
  #35
Cook's Avatar
hopefully this is it:
pin 42 activates giving power to the fan thats already grounded. fan works by itself.
AC trigger wire energizes activating the relay on the left giving the left fan power, while the middle relay also activates due to the ac trigger wire energizing giving the fan ground through the other fans circuit. even if pin 42 isnt activated BOTH fans will be on.
alright, im off for the night! i feel pretty confident about this one.
Old Jan 24, 2011 | 12:05 PM
  #36
Cook's Avatar
bump, any ideas?
Old Jan 25, 2011 | 08:12 PM
  #37
MikeGyver's Avatar
Well that last one will work. I was waiting for someone to say if pin 42 is energized during A/C also.
Old Jan 26, 2011 | 09:13 AM
  #38
Cook's Avatar
sahweet. thanks.
D1SCSS
Jan 25, 2016 10:14 PM
pjb1972
Sep 17, 2015 02:06 PM
fillpot
Jul 26, 2015 07:21 PM
Ketis
Jul 23, 2015 12:37 PM
