E-Fan guys get in here (2003 silverado)
#31
It was turned on, i use to have a clutch fan, when i gave him the pcm i had him turn it on, i know its turned on because of the codes. they wouldnt be there if it wasnt turned on
#32
ok i thought i had it. i figured i would have the middle relay's coil activated by the + AC trigger AND the pin 42 ground signal. that way it would only activate when both were on. but...i ended up with this
that way the left fan can be on by itself, but when the AC is turned on BOTH have to turn on, even if PIN 42 isnt energized.
#35
hopefully this is it:
pin 42 activates giving power to the fan thats already grounded. fan works by itself.
AC trigger wire energizes activating the relay on the left giving the left fan power, while the middle relay also activates due to the ac trigger wire energizing giving the fan ground through the other fans circuit. even if pin 42 isnt activated BOTH fans will be on.
alright, im off for the night! i feel pretty confident about this one.
D1SCSS
Jan 25, 2016 10:14 PM
