DTC's Any suggestions
Old May 27, 2006 | 01:15 PM
krambo's Avatar
Default DTC's Any suggestions
I got 0120 (throttle peddle communication) and 2135 (???). I assume it was from when the engine got wet during a thunderstorm (hood was up for about 1 minute during a heavy rain). It has been a day and they still will not clear, runs in "reduced power mode". Any suggestions on these?
I can get the 0120 (returns about 3 minutes later) to clear but the 2135 is bugging me.
Old May 27, 2006 | 03:16 PM
Nick™'s Avatar
P2135 - throttle/pedal position sensor/switch A/B correlation
I would suggest unplugging the connector at the throttle body and letting it hang off overnight, with the hood closed of course... the connectors are supposidly water tight, water may have gotten in and not be able to get out, if it's just wet hopefully this will give it a chance to dry.
another thing to try is to unplug the throttle body, turn the key on for a few seconds, then turn it off, replug it and then start the truck... maybe that will reset the correlation?
Old May 27, 2006 | 04:36 PM
DrX's Avatar
DrX
Happened to me after a trip to the carwash. Pulled the connector, blew it out with compressed air and it worked fine afterwards.
Old May 28, 2006 | 08:34 PM
krambo's Avatar
you guys got it. There was moisture in there,...blew it out and no issues. Water tight my ***.
Gadgetized
Oct 22, 2015 09:06 AM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
The_W
Oct 1, 2015 02:35 PM
Slammed silverado
Sep 28, 2015 06:14 PM
sTNT971
Sep 26, 2015 04:22 PM
