Do I need a retune for ported heads?
Old Jan 19, 2009 | 04:54 PM
GMCtrk's Avatar
Default Do I need a retune for ported heads?
Yes, I know I'll need a retune for optimum performance, but will it be safe to run on the current tune. I'm assuming it will go lean because of the extra air getting in, but the computer should be able to correct right? Reason being, due to my exhaust leak at the header my gas mileage has gone to utter **** and I need to get these new heads on asap.
Old Jan 19, 2009 | 05:11 PM
BlackGMC's Avatar
Resident Retard
I would imagine it would atler your VE table, and your MAF table.... Also I bet you need to take a look at your timing, depending on the bowl work and compression you may get to add some timing since the combustion chamber is more effiecient or it maybe be the opposite you might have to take away some timing....
Old Jan 19, 2009 | 05:19 PM
do you have a wideband?
Old Jan 19, 2009 | 06:01 PM
hirdlej's Avatar
Most definatly
Old Jan 19, 2009 | 10:08 PM
GMCtrk's Avatar
the stage 1 ls6 heads dont have any bowl work done on them, but my compression is going up half a point
Old Jan 19, 2009 | 10:24 PM
dc_justin's Avatar
Hello Dave
Assuming comparable combustion chamber design, increased compression would require a timing reduction.
Silveradorst07
Dec 31, 2015 12:04 AM
greedygenius
Sep 3, 2015 06:51 AM
Verz
Aug 21, 2015 06:40 PM
jmarkway
Jul 18, 2015 09:23 PM
4B11T
Jul 13, 2015 03:48 PM
