Do the '99/'00 PCM's really suck as bad as some say....I don't think so, here's why:
Old Jul 11, 2006 | 11:54 PM
Yelo's Avatar
Originally Posted by Zick
How come? They both have the same table but they don't work the same.
The code that references that table has changed (improved) so, the numbers in that table mean different things to the dfferent codes, kind of like if I was to put the knock sensor numbers that work for a '99/'00 into a '01-'04 you could hit the side of the motor in the '01-'04 with a ball-peen hammer and the knock sensors would be completely deaf to it, the two computers have different algorithms for processingt the numbers in that table....so you get two different results from the same numbers
Old Jul 12, 2006 | 10:08 AM
Zick's Avatar
Ah gotcha, how did you come across this info?
Old Jul 12, 2006 | 10:09 AM
Zick's Avatar
Originally Posted by Wilde Racing
different ECM O.S systems..... check out the Genral pressures tab on a 02 compaired to a 99-00
I wish I had the General Pressure tab available on mine.
Old Jul 12, 2006 | 10:59 AM
Yelo's Avatar
Trial and error, file comparisons, ALOT of research, and a little bit of luck....I've spent the last 6 months figuring out WHY the '99/'00 PCM is supposedly so bad, I've determined that it's not the OS code that's bad, it's the people trying to tune them using numbers that work in the '01 and later PCM's that causes the problems. the '99/'00 PCM's require a completely different set of numbers in some of the tables than the '01-up PCM's to achieve the same effect
Old Jul 12, 2006 | 12:34 PM
Yelo's Avatar
upgrade to 2.1.12 and you will....
Old Jul 12, 2006 | 12:41 PM
Zick's Avatar
I did but all I get is a blank page for the General Pressure tab.
Old Jul 12, 2006 | 12:42 PM
Yelo's Avatar
You didn't say you actualy wanted to SEE something on the tab ....I think it's '04 or '05 and newer that actually have the tab enabled.
Old Jul 12, 2006 | 12:45 PM
Wilde Racing's Avatar
How do I change this text
Nope it's the 01-02 ECM's that have the tab enabled.
Old Jul 12, 2006 | 12:47 PM
Yelo's Avatar
Thank you...I wasn't sure. Is it disables on the '03 and newer then because Zick says he can't see anything on that tab and he's got an '03 ??
Old Jul 12, 2006 | 01:20 PM
Thank you, now I can fix up a few of my friend 99-00 trucks without buying a 02 ECM.
