Do the '99/'00 PCM's really suck as bad as some say....I don't think so, here's why:
Originally Posted by Zick
How come? They both have the same table but they don't work the same.
Originally Posted by Yelo
The code that references that table has changed (improved) so, the numbers in that table mean different things to the dfferent codes, kind of like if I was to put the knock sensor numbers that work for a '99/'00 into a '01-'04 you could hit the side of the motor in the '01-'04 with a ball-peen hammer and the knock sensors would be completely deaf to it, the two computers have different algorithms for processingt the numbers in that table....so you get two different results from the same numbers
Ah gotcha, how did you come across this info?
I did but all I get is a blank page for the General Pressure tab.
....I think it's '04 or '05 and newer that actually have the tab enabled.
How do I change this text
You didn't say you actualy wanted to SEE something on the tab
Originally Posted by Wilde Racing
Nope it's the 01-02 ECM's that have the tab enabled.
Thank you...I wasn't sure. Is it disables on the '03 and newer then because Zick says he can't see anything on that tab and he's got an '03 ??
