DFCO brake pedal trigger?
Old Jul 13, 2012 | 11:38 PM
oakley6575's Avatar
Default DFCO brake pedal trigger?
I was wondering if anyone else has the same problem that I do. When DFCO is enabled, the tcc is locked. When I press on the brake, the tcc unlocks immediately and DFCO stays active. This causes an extreme drop in rpm and the motor has to catch itself from stalling. I guess it's not really a problem, but it annoys the hell out of me. Why doesn't hp tuners have a way to deactivate DFCO when the brake is applied? Isn't that how the factory tunes DFCO?
Old Jul 14, 2012 | 01:00 AM
Atomic's Avatar
I have a gauge for that
You can modify the dfco entry and exit settings...but add some more advance during dfco to prevent the big drop in rpm
Old Jul 14, 2012 | 11:33 AM
oakley6575's Avatar
Yea all the entry and exit settings are changed to how I like them. I just don't like the big drop. How much advance are you running during dfco? Mine goes to 0 advance. Should it be more around 10 degrees?
Old Jul 14, 2012 | 12:19 PM
cammed00's Avatar
When I slow down and hit around 42mph my DFCO kicks in and it does acouple jerks and it annoys the **** out of me!
Old Jul 14, 2012 | 12:34 PM
Atomic's Avatar
I like 8 degrees
Old Jul 14, 2012 | 01:02 PM
oakley6575's Avatar
It looks like the active spark tables arent used. Why is that? Does it only use the entry and exit spark tables?
Old Jul 14, 2012 | 03:19 PM
Atomic's Avatar
It uses the "Spark Advance Table A/B" in the "DFCO Active Spark" section.
Old Jul 14, 2012 | 05:35 PM
oakley6575's Avatar
Yea those are the tables I'm referring to. Under each table it shows a throttle position percentage that must be exceeded before that table is used. On all the tunes I've seen, those percentages are 99 and 100%.
Old Jul 14, 2012 | 06:06 PM
Atomic's Avatar
Yea, I think they defined it wrong, mine uses the b table
Old Jul 14, 2012 | 06:39 PM
oakley6575's Avatar
Thanks man. I will see if I get that drastic drop with higher spark advance.
RustyD
May 23, 2016 07:04 PM
turbo6c3
Oct 5, 2015 06:11 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
01silvy
Sep 26, 2015 10:20 PM
Alco
Sep 4, 2015 04:08 PM
