DBW pedal is 100% WOT at 1/2 pedal travel
Old Sep 6, 2011 | 12:46 AM
  #81
Jim_PA's Avatar
Originally Posted by BryanD
with tune OS = 12587811
TAC 12588923, (can't read number on pedal) gave me 100% pedal = 50% throttle blade. the pedal is the metal adjustable short throw style.
TAC 12590008, PEDAL 15107594 gave me 100% = 100%. this pedal is the short throw plastic one.
TAC 12588923, with LARGE THROW NON-Adjustable metal pedal also gave me 100% = 100%
So, still somewhat mysterious IMO. so for me the same tac module produced different results depending on what pedal used. sounds like the pedal sensors must be different then. unfortunately i can't read the numbers on the pedal sensors.
I have 2 TAC modules with 12573059. With the big throw, non-adjustable pedal, I get 100% WOT at 50% (or so...) of pedal travel.
All ebay auctions I've looked at say that 12588923 superceeds 12573059.... I need to make mine work! --
Old Sep 6, 2011 | 07:52 AM
  #82
Jim_PA's Avatar
So, now that I've had more time to think about it:
if 12573059 and 12588923 are indeed the same, I should be able to change my OS to 12587811 and my current TAC and pedal should work.
I'm still hesitant to change OS's at this point with the other custom work I've had done to it. I guess it's time to check compatibility of segment swapping my AC changes and weather or not an EFILive COS3 is available for 12587811
Edit: No COS3 for 12587811. Damn.
Old Oct 19, 2011 | 04:14 PM
  #83
Jim_PA's Avatar
Well, as a follow-up.. I've been driving the new swap car for about a month now, and I'm worried about my clutch life. If I can concentrate heavily on extremely lightly feathering my gas pedal, all goes well. But if I'm trying to get up and go in a hurry, My gas pedal foot tends to bump the throttle a bit more heavily.. Not good for the clutch!!!
So, as a hopeful work-around, I observed TP% while doing what I consider "bumping" the throttle while pulling out, and TP% goes up to usually about 50% in what I consider normal pedal actuation. Seems a bit aggressive to me
So, I started messing with B2308 "ETC pedal response"
Stock values from 12.50% to 50% pedal go like this, along with my 50% reduction:
pedal % - Throttle % (stock) - Throttle % (with my modifications)
12.5 - .381 - .190
15.63 - .586 - .293
18.75 - .947 - .474
21.88 - 1.377 - .688
25.00 - 1.895 - .947
28.13 - 2.539 - 1.270
31.25 - 3.389 - 1.694
34.38 - 5.703 - 2.852
37.50 - 7.5 - 3.750
40.63 - 9.6 - 4.8
43.75 - 12.002 - 6.001
46.88 - 14.502 - 7.251
50.00 - 16.904 - 8.452
After multiplying the values up to 50% by 1/2, I added a sharp curve from 50% up to 100%.
I realize that by doing this, I've lost some pedal granularity above 50% throttle movement, but in reality, it's pretty rare I'm looking for pedal control/granularity above half throttle anyway.
In the driveway, the pedal feels MUCH more reasonable now, and I might have taken away too much, but I'll have to reserve that judgement until I do some driving.
I have my fingers crossed that the modifications don't trigger a limp mode or fry my PCM (as warned about in the editor...) but I'll have my laptop and a backup file on hand in the event that it does.
Wow, what a difference it makes in overall low-speed/throttle driveablitiy!!! It's totally tamed the stabby throttle issue and pulling out isn't such a teeth clenched operation anymore. I haven't verified that I'm still getting 100% WOT on the butterfly, but I can't see why any of these mods would have stopped that from happening.
Give it a try if you're tired of an ultra-touchy throttle because you have pedal/tac/software mismatch issues.
Old Oct 19, 2011 | 09:54 PM
  #84
BryanD's Avatar
Jim,
Good work. i'm definitely filing this data away.
i would possibly guess that your engine/tune/pedal/tac, etc. came from an automatic trans car and now you are using it with a manual? you probably mentioned in a previous post, just too lazy to go back.
Old Oct 19, 2011 | 10:20 PM
  #85
Jim_PA's Avatar
Jim,
I didn't personally pull any of the test pieces I've used, so I can't confirm where any of them really came from. Everything I've used was supposedly from an auto truck though. And yes, I now have a manual trans.
I've come across a theory that it's the throttle body that dictates which pedal and tac is compatible. Some TB's want 0-5v, some want 0-2.5. However, the bottom line is that there are way too many inconsistencies to draw a conclusion about anything.
It has been reason enough for me to not bother swapping pieces around hoping to get the magical combination of everything
natejk
Nov 15, 2016 08:05 AM
kalikid06
20
Oct 13, 2015 07:37 AM
Superman09
Sep 25, 2015 05:55 AM
creekrat
Sep 10, 2015 12:59 AM
