It cranks but won’t start
was running fine and then a evap and misfire cylinder 7 code. While driving engine sputtered a little like it was running out of gas then shut off 1/4 mile down the road. It did crank and try to start maybe 6 times then only crank
currently cranks but won’t start
I changed crank sensor
I can smell fuel and has a full tank
new wires
any ideas?
I have to pull codes again to see if any new ones and need to verify spark
other strange things are
Dim headlights
Fast flash only on the driver side that comes and go's
poor performance
grounds were very bad cleaned them and found that if I grounded to coil harness the truck would start and run. I also changed the plugs. Glad I did the plugs had a buildup on the electrode. Misfire seems to be gone. Still chasing the abs/wheel speed light.
new wires
any ideas?
Dim headlights
poor performance
Showing a ground for the pcm at the back of the intake on the passenger side and also grounding the coil harness on the drivers side.
So it started..
I installed a new ground wire to the driver side coil pack and it fired up right away. Not sure how I lost that ground but it did. I still have a few codes
p0300 random misfire
c0035 wheel speed sensor front new
c0040 wheel speed sensor front new
c0055 wheel speed sensor rear original
The search continues
Do you still have the dim headlights issue? If so check the harness to radiator support ground (driver side front of support). This is the ground for everything mounted to the core support including the headlights.
