cranking problems
Old 09-27-2011, 11:23 PM
  #21
11 Second Hall Moniter
AKlowriderZ71's Avatar
Oh, and stop trying used batteries. Your truck is special, and it doesn't appreciate second hand parts.
Old 09-27-2011, 11:34 PM
  #22
Bumpers's Avatar
I will mess with it some more and see if I can find anything.. I doubt my engine is seizing up and if it is I'm just gunna set the truck on fire and call it a loss lol.. Its gotta be something small just gotta find it
Old 09-27-2011, 11:45 PM
  #23
I wish I could help more. If you were near here, I'd test & diagnose it for you, N/C. The new MidTronics testers will quickly & easily test your battery, test your starter draw, and even tell you if it has a bad connection.
Buy me a plane ticket, I've never been to Mississippi. I'll even buy you a new battery!
Old 09-28-2011, 12:06 AM
  #24
Bumpers's Avatar
Haha if I can't figure it out I may have too electronics and wiring are really my weak point as I hate them with the passion of 10000 burning suns.
Thanx for your help.. I really appreciate it
Old 09-28-2011, 12:09 AM
  #25
You'll get it fixed, and you'll laugh about it someday.
Be sure to post up what you find, seems like alot of threads get started, but never post the ending.
Old 09-28-2011, 12:10 AM
  #26
Baltimore Whore
Mangled03gmc's Avatar
I didn't mind to read all the comments, but get under there and check the connections to and from the starter.. You seem to have eliminated the battery and possible grounds.. I say it is a starter issue, loose wires/connections or your starter is on its way out...
Old 10-02-2011, 01:29 AM
  #27
iamkeniff's Avatar
Its bc you turned it into a race truck
Old 12-05-2011, 09:54 AM
  #28
Bumpers's Avatar
Well I replaced the ground wires thinking they may have been a culprit but it did nothing other than my windows roll up quicker now the factory ground wire that went to the engine had some buildup in it so I thought it may be giving me a problem but now I have 2guage goin from the engine to the batt, and 4 guage to the frame and body so now I know its not the ground wires as well.
I would really like to fix this but I have no idea anymore
Old 12-05-2011, 12:17 PM
  #29
iamkeniff's Avatar
sell the truck and buy a dmax with a 6" lift on 38s problem solved
Old 12-05-2011, 09:45 PM
  #30
99LsSilverado's Avatar
You should check the positive cable to the starter because if there is any corrison there it will have issues. What you could do is take a set of jumper cables and hook the one end on the positive post of the battery and the other on the starter and see if it turns over any differently.
Quick Reply: cranking problems
