Could TC slippage pull timing?
Old Sep 10, 2009 | 08:16 AM
fastgmc53's Avatar
14 Second Truck Club
Default Could TC slippage pull timing?
Took my truck to the track last night to get some times with the stall nefore i do my cam swap. Used to run 14.7's before the 2600 stall at 96. Had 93 octane and a bottle of booster but ran 15.2 at 90.... I dropped tire pressure to 20 and hooked up perfect but it chattered bad on the top end... Drive home was fine pulled like a beast but it chatters when it hooks up. I haven't had tunr re-done for the converter yet could it be??
Old Sep 10, 2009 | 08:24 AM
BlackGMC's Avatar
Resident Retard
What do you mean chatters??? From my understand losing some topend with a larger torque converter is not uncommon, but that is usually on the larger TCs, i would not expect that from 2600... Who does your tuning?
Old Sep 10, 2009 | 09:18 AM
KLUG'S SS's Avatar
FormerVendor
What was the weather like as far as air temp, humididty, etc... compared to the 14.7 run you ran previously? I mean it shouldnt make that big of a difference unless the tune is kind of jacked up.
Old Sep 10, 2009 | 12:58 PM
fastgmc53's Avatar
It ran a 14.8 at 96 spinning off the line with the converter but when i drop pressure and it hooks off the line the computer must go into a safe mode... Chattering is noise in the cylinders when either cheap gas or timing is wrong. Blacbear tuned it but i haven't had it redone for the converter.... I was just hoping same thing has happened so i know its the tune. Humidity was higher this time but that should not affect it that much
Old Sep 10, 2009 | 03:00 PM
xlcooplx's Avatar
so the chattering you are hearing is actually spark knock, correct?
Old Sep 10, 2009 | 04:32 PM
fastgmc53's Avatar
Correct...
Old Sep 11, 2009 | 06:42 AM
xlcooplx's Avatar
I see you have a CAI...is it an oilable filter? if so, have you recently cleaned your MAF? if not, i'd start there. it also wouldn't hurt to run some seafoam through the motor to try and clean the top end.
Old Sep 11, 2009 | 09:30 AM
fastgmc53's Avatar
Cai is a dryflow and i seafoamed it a week ago... It only does it when i hook up good if it spins theres no issue. My 60 foot time is the same whether it spins or hooks up so it must start pulling timing immediately. I know i need a retune just hoping someone else has had the same prob to confirm...
Old Sep 25, 2009 | 06:09 PM
2000Redstep's Avatar
Just wondering how you made out. I think I have a similar problem. Added my stall and exhaust after the tune and it feels slower.
Old Sep 25, 2009 | 07:14 PM
fastgmc53's Avatar
I'm sending it out to blackbear for a touch up first of the week..... Thats gotta be it though.
