COS3 Rocks
Old Nov 6, 2008 | 04:49 PM
Mort's Avatar
Default COS3 Rocks
I am really happy with the way my truck is running for the first time since I put the new engine in back in May.
The throttle response is really a lot better and it seems to rip at part throttle. Will have to wait till the weekend before I get to experiment in the upper realms. Traffic to and from work is just too thick and the drivers too unpredictable.
I tried tuning the MAF but could not seem to figure it out so I gave COS3 a try. The MAF was not bad when I lowered the whole table along with the VE table by 10% but it leaned out by almost a point over 4400 rpm at WOT in PE mode.Also the tune ran almost as rich in daily driving as it did before I lower the MAF curve and VE table. Something in the stock tune seems to be adding a lot of fuel everywhere.
COS3 gave me a few problems at first but I have them worked out enough to fine tune it now without the urgency I seemed to be under before trying to get this truck running better since May.
The idle was better under the MAF until I tried to tune it and it started to stall all the time even when I put all the settings, except spark, back to stock. Under COS3 I did another RAFIG and raised the idle 100 rpm once the engine warmed up to 44*C in the whole bottom of B4603 Desired Idle Speeds. Idle speed is now 665 vs 575 stock. This seems to have solved the problem for the most part and while I still get the odd bump it has not stalled out yet.
Under the MAF throttle response was poor and in COS3, with 1 round of AutoVE, it seems to be very crisp and smooth in the transitions. The problem I had was it would go really rich quickly crossing 105 kpa and the truck would buck a little and bog out. I had to back out of it and accelerate really slowly to work through this area. I finally set the 100 kpa column of B3647 to 12.5 above 3200 rpm and set my PE to 110 kpa and a max of 11.5. Then I took the Boost VE table A0009, which is set really rich in the COS3 setup, and set the whole thing to 5% above the 105 kpa column for the whole table and the truck seems to really rock now.
I am relying on the PE for now unless it will not hold at WOT. I have no idea what would happen if I just relied on the B3647 and A0009 but I guess it might be quite lean. So now I need to tweak the idle a little if I can figure it out and definitely AutoVE the B0101 table a bit more and see if I can get the A0009 Boost VE Table to play nice.
Feeling much better about the whole deal now.
Thanks for reading and sorry for the long post.
Zizzle
Oct 19, 2017 08:44 PM
natejk
Nov 15, 2016 08:05 AM
11MPG
Sep 10, 2015 08:34 PM
JFOLM
Sep 10, 2015 07:37 PM
the owl
Sep 4, 2015 04:09 PM
