COS3 Lean Cold Startup
Old Mar 18, 2009 | 05:37 PM
Mort's Avatar
This is what I have in A0008 and this is leaned out some and does not go to as high an ECT as the original. It does got to a higher ECT than the table above. Give it a try.
-40*C 1.4
-30*C 1.4
-20*C 1.35
-10*C 1.3
0*C 1.271
10*C 1.214
20*C 1.175
30*C 1.125
40*C 1.075
50*C 1.00 and up to 110*C
110*C 1.064 and up to 140*C
What is your Commanded AFR in {B3647}. Is it the same in {B3649}? To do AutoVE both tables should be the same. Also do not set it to 14.63 or 14.68 or STFT may be enabled. Set it to 14.7 when doing AutoVE. I believe {B3647} enables STFT when set to stoich. Not sure if that means 14.63 or 14.68 or the one set in your tune in the Menu Edit...> Properties...> Display.
What injectors are you running? You may want to have a look at {B4005} Small Pulse Adjust. This is an adder and will be added to injector on time when very short injector on time is commanded (between 0 - 4ms as set in {B4006}.
Old Mar 18, 2009 | 06:10 PM
Phantom's Avatar
11 Second Club
Josh that yellow vette of steves idles at ~18afr
Old Mar 18, 2009 | 06:33 PM
viciousknid's Avatar
Where's the Beef?
I set my a0008 to stock and recopied the first couple rows of my VE table from an old tune. was a little rich this morning. So That must have been the problem.
Old Mar 18, 2009 | 06:51 PM
Mort's Avatar
Sounds good. Nice when something you try works out.
madmann26
Apr 29, 2020 09:17 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Chevy305
Sep 28, 2015 09:21 PM
