COS3 Lean Cold Startup
Old Feb 14, 2009 | 09:45 PM
viciousknid's Avatar
Where's the Beef?
Default COS3 Lean Cold Startup
Still searching EFILive for a solution but not having luck. Posting here as I continue my search.
Cold start up runs 17-18 afr until maybe 175 temp is reached. Once it does It goes back to where it's commanded, and then a few minutes later it richens up to 13-14 instead of 15 where I want it.
Any tips or links to threads are greatly appreciated. Just trying to get my tweaks figured out before I drive back home after work.
Since i'm at the 500 mile mark I plan to make sure my VE table is dialed in. Still kind of skeptical about the wideband accuracy whit the EFI reading.
Old Feb 14, 2009 | 09:49 PM
dirt track racer 81's Avatar
in the efilive custom calibration A0008
Old Feb 14, 2009 | 10:24 PM
Where's the Beef?
its 1.00 all the way
Old Feb 14, 2009 | 10:27 PM
at the colder temps raise it up and it will run richer until you get to operating temps
Old Feb 14, 2009 | 10:31 PM
Where's the Beef?
gotcha. Any tips on the incriments of increase? 1.23 versus 1.5?
Old Feb 14, 2009 | 10:46 PM
this what i have.. dont know exsactly what it is running but its a start for ya 1.200195
1.155274
1.110840
1.066895
1.022461
1.009766
1.000000
1.000000
1.000000
1.000000
1.000000
1.000000
1.000000
1.000000
1.000000
1.000000
1.000000
1.000000
1.000000
Old Feb 14, 2009 | 10:47 PM
Where's the Beef?
So small variables. I was reading on EFI and some people are having problems with it not working. So i'm hoping i'm not one of them.
Everytime I start the truck and I see --- on my wideband my toes curl (pun intended).
Old Feb 14, 2009 | 10:55 PM
its not going to hurt anything running that lean at idle.. fuel injected cammed for cars like lean 17-18 afr..but a stock cam needs to be richer.
Old Feb 14, 2009 | 10:56 PM
Where's the Beef?
aight den
Old Mar 17, 2009 | 04:47 PM
Where's the Beef?
Bumping this thread. The above worked great until recently. After I put the stall in I've been redoing the ve table. Seemed way out of whack.
Now i'm starting upt at 14.8 and about 5 seconds later it leans out to 18.8. I've tried increasing these tables again but doesn't seem to be helping.
I'm working on the RAFIG process but I don't want it to sit there idling at almost 19:1
