Converter slipping or my 80e??
Old Jul 11, 2013 | 11:37 AM
Default Converter slipping or my 80e??
I logged all the trans pids I thought would tell the tell but I don't know what to look for Which pid in hp tuners will tell the tale? This is in my crew and it's a stock 80e,stock stall with a pretty aggressive tune. It still barks second at wot but it will flare rpms before the shift,feels like it doing it on the 3-4 shift also. Thanks
Old Jul 11, 2013 | 11:39 AM
Atomic's Avatar
I have a gauge for that
Upload the log file.
You want to look at trans input rpm compared to output rpm. These should be seperated by the trans ratios, 2.48, 1.48, 1, .75. You will see the torque converter by comparing engine rpm to trans input rpm.
Old Jul 11, 2013 | 11:43 AM
Man you've helped me a bunch...Thanks!! I didn't save the log this morning but I will log again on the way home.
Old Jul 11, 2013 | 12:10 PM
slow67's Avatar
Gingervitis Addict
Actually 4th will still be 1:1 comparing ISS to VSS rpms, as the ISS is after the overdrive planetary.
Old Jul 11, 2013 | 12:31 PM
Atomic's Avatar
Ah, good catch. I use the VSS on my transfer case, so mine is correct.
Old Jul 11, 2013 | 04:05 PM
Here is the log and config I was using.trans slip.hpl
trans pid.cfg
Old Jul 11, 2013 | 04:34 PM
chevrolet all the way's Avatar
35-37sec into the log. that's a slip for sure
Old Jul 11, 2013 | 04:55 PM
Yeah that's what I'm afraid of...I'm not pissed if it needs building because it's first 85,000 was behind a damn 16 passenger 3500hd bus lol. I have beat the **** out of it for the last 10,000 in the crew. May bring it down to Trussville if I can get a deal on a rebuild
Old Jul 11, 2013 | 05:08 PM
haha well i know a guy if you need some help
Old Jul 27, 2013 | 01:16 PM
Got around to pulling the pan today and I was pleased to see no shavings...but the pan is full of graphite looking material?? lockup clutches?? I cut the filter open and found some small black particles, the fluid smells burnt but doesn't look metallic
blownss27
Aug 14, 2020 08:27 AM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
JordanH
Jul 14, 2015 03:46 PM
