Codes driving me crazy!!!
Yes. The PCM is tuned for the engine you have. If you take that engine out and increase or decrease cubes then you need to re tune to compensate for the different Cylinder mass.
P0174, fuel trim system, lean bank 2. Did you mean P0171 for the first code? That is the same, but bank 2.
If both of your codes were lean, then yes, a fuel pump could of course do that.
Otherwise, did you switch injectors with the engine? That would throw the tune way off.
Heres an update, I switched back to my old injectors and retuned (1/6/11) for the 5.3, the truck ran great until today, the check engine light came back on and started idling rough. I don't want to think about it, but is it possible the cylinder is gone once again?
Last edited by javiles; Jan 20, 2011 at 04:56 AM. Reason: I had the wrong retune date.
If you've been driving around lean for this entire time and finally re-tuned per our advice then yes, you could have burned it up. Lean is always bad.
Are you getting the same codes?
I am not sure, I didn't drive it that way for more than a couple miles, I went ahead and parked her until my tuner was free, I'm sorry the day I retuned was the 6th of January not the 17th, she was running good until yesterday. I feel dumb for giving the wrong date. But yes retune date was 1/6/11 and Ive driven her around 800-900 miles since then trouble free, no codes, no acting up whatsoever until yesterday, as far as codes go I will be checking them out as soon as the local auto parts opens. Its really worrying me as you can see, its 5am and I cant sleep.
Thanks, I suspect the same, I know there seems to be endless questions from me and I apologize. I did a little research and came up empty, I am curious as to what brand o2 sensors to go with? Correct me if I am wrong but Delphi is OE correct? Could I use Bosch OE type/ exact fit? Thanks once again.
Thank you for your help, as soon as I get out of class I will stop by to get the o2s and install them later tonight.
