Code P0106 - MAP sensor
Old Mar 9, 2007 | 01:54 PM
Tootall's Avatar
Default Code P0106 - MAP sensor
I'm getting code P0106. The only time that I get this code is I turn key, and start driving when the engine is "cold." After it's warmed up, it'll go away. On a cold start; if I let the engine warm up for 2-3 min, then it's fine/ok.
What's the differences in the two. I have no EGR, so I don't see if there's anything that warms up in the intake. I just did a motor swap and had no prior issues with any codes at all. Again, this only happens when I cold start, and start driving, never once it's warmed up. The engine is a 6.0 with a 222/224 -112 cam.
Old Mar 9, 2007 | 02:28 PM
foff667's Avatar
LS1TECH Sponsor
theres a few sanity checks within the pcm...your probably just out of range at cold startup...should be able to be tuned out with no ill effects though.
budhayes3's Avatar
PT's Slowest Truck
Could it be something with the tuning? Maybe the map sensor isn't seeing enough manifold vacuum due to the overlap of the cam?
Old Mar 9, 2007 | 02:50 PM
Tootall's Avatar
"tuned out" . . . do you mean " do not report" or just delete it out?
forgive me I know nothing about the tuning side.
Old Mar 9, 2007 | 02:55 PM
foff667's Avatar
LS1TECH Sponsor
neither...you'd need to adjust the limits of the test.
natejk
Nov 15, 2016 08:05 AM
Tydriver
45
Oct 23, 2015 09:19 PM
chvy=power
Oct 20, 2015 09:08 AM
Pimpinpete
Sep 8, 2015 07:39 PM
muncie21
Sep 7, 2015 09:55 PM
