Chasing my wideband around with voltage offset
Old Jul 3, 2013 | 07:40 PM
boostedc10's Avatar
Default Chasing my wideband around with voltage offset
Guys,
Anyone ever had an issue where you are chasing your wideband around with voltage offset. I was trying to get them close and noticed my gauge would read 14.3 and HPTuners reading 13.4 so I adjusted the offset to make up for the .9 and next thing i know the wideband starts to go more lean to 15.3. I change the offset again to adjust and again I watch the gauge move away again.
This is an Innovate LC-1
I hope someone understands what I am talking about and knows what might be the issue. I really would like to tune using the wideband over fuel trims, but really have no clue what the issue is.
I plan on calling Innovate tomorrow if they are open to see what they may know but figured I would see if anyone here has any ideas.
(P.S. For you HPTuner forum goers, yes its an identical post )
Old Jul 3, 2013 | 08:23 PM
03sierraslt's Avatar
By what means are you adjusting the offset? Are you using the HPT EIO voltage table for your wideband and tweeking it? When you say you make a adjustment then it goes lean I am assuming you are using that table. How much are you changing the voltage?
Old Jul 3, 2013 | 09:52 PM
boostedc10's Avatar
Yes I am using the HPT EIO to adjust it. As for how much am i changing the voltage, I have been as much a 2 and as low as .2 chasing the gauge.
The formula is volts/0.5 + 10 but i have been as low as 8.2 trying to match them, and as stated before the more i try to get close to the gauge the further the gauge goes out.
SS94S10
Jan 3, 2019 01:57 PM
muncie21
Sep 7, 2015 09:55 PM
madmann26
Sep 6, 2015 04:19 PM
Cakes
Sep 6, 2015 02:57 PM
xerox17
Sep 5, 2015 01:23 PM
